PRB showing up as PRA in K Manager
M111
Post by M111 »
Hi,
My PRB ECU shows up as a PRA in the K manager software, I'm in the UK so guessing someone has fitted a board programed for a PRA into the PRB.
Questions is, will this cause any problems with the software or ECU?
Re: PRB showing up as PRA in K Manager
If you have a PRB ECU then you should use a PRB based calibration.
M111
Post by M111 »
Just uploaded a PRB cal to it & it now shows as a PRB, the one it came with must have been a modified PRA cal.
I assumed it was reporting the ecu type, not the cal file.
Cheers.
