Autotune
Morikun
Autotune
Post by Morikun »
Can someone please explain to me how to use autotune?
Morikun
Re: Autotune
Post by Morikun »
Never mind. I found it when I searched google (but not when I searched the forum?!).
https://www.hondata.com/forum/viewtopic.php?t=12801
Morikun
Re: Autotune
Post by Morikun »
And seriously, how am I expected to drive around while holding down ctrl+T...
Re: Autotune
For safety any tuning should be done with 2 people.
Morikun
Re: Autotune
Post by Morikun »
Well, I tried driving around holding ctrl+T for a little bit...didn't seem to do much.
92 Hatch
B20vtec, 11.5:1, BC stage 2 cams, s300, itr tranny
NA for freedom :)
Morikun
Re: Autotune
Post by Morikun »
Tell me please if this method for autotune is correct or not:
1. Load calibration.
2. Set as base.
3. Drive around under different loads to get a good average lambda correction suggestion.
4. Ctrl+T (which then autotunes the lambda suggestions).
5. Set as base (so that the newly autotuned map is the current base from which to tune against).
6. Drive, ctrl+T, set as base.
7. Drive, ctrl+T, set as base.
8. Drive, ctrl+T, set as base.
9. Drive, ctrl+T, set as base.
10. Drive, ctrl+T, set as base.
Am I getting this right?
The only advantage to holding ctrl+T while driving is that the changes are made in real time, correct?
Re: Autotune
It will only autotune when CTRL-T is held down and you are driving around. Just pressing it with a datalog will do nothing.
I personally do not find the autotune feature to aid much in my own tuning as it tends to make jagged lines and then I have to clean it up. I find it easier to drive around and record then come home and make some changes and drive around and record again, then make any needed changes.
Morikun
Re: Autotune
Post by Morikun »
Oh okay.
Those instructions for Autotune I found were for Hondata Romeditor. Sounds like a more efficient way of using autotune, because it takes averages over multiple load conditions as opposed to tuning it in real time (and resulting in jagged fuel curves).
Know what I mean?
92 Hatch
NA for freedom :)
deltoid61
Re: Autotune
Post by deltoid61 »
You dont have to keep holding Ctrl+T all the time.Just one time is enough. If parameters/settings are done right you will hear sounds of it making chnages in real time.Here check this out
https://youtu.be/G2ukmAB4O50
Jv sol
Re: Autotune
Post by Jv sol »
It seems that the kpro v4 has the one button press autotune with sounds when changes are made. If I'm not mistaken and please let me know if it's incorrect but the s300 v3 does require you to continuously hold ctrl t while driving around. My question is does it require you to be in open loop closed loop disabled to function or does it function in any setting? Ie: closed lambda target
Re: Autotune
CTRL-T must be held down for the s300. It is best to do it in open loop so that the closed loop settings are not fighting against you.
unregistereduser
Re: Autotune
Post by unregistereduser »
There are programs that you can download to simulate/hold keystroke. Macros and autoclickers and such. Just have to search around
deltoid61
Re: Autotune
Post by deltoid61 »
Here i found a detailed video on youtube. supposidly you need to press CTRL+T once to start but if not just that. setting the parameter and ticking the correct options will enable autune otherwise the option for autotune will be greyed out. This dude is tuning even his turbo maps with autotune !!
https://www.youtube.com/watch?v=G2ukmAB4O50
