Boost control with BOV
9queSt
Post by 9queSt »
Try to keep this on topic.
Can the bov be opened via Mac solenoid and nitrous output to help control boost.
The car is a drag car and I would only open the bov in first gear. The lowest boost is at 15psi with wastegate off the car. If I open up the bov id like to see 8psi.
Re: Boost control with BOV
You should just use the waste gate to control boost, as this is what it is designed for.
The turbo will over speed if the wastegate is closed and bypass valve open.
