*BUG* for both fpro and kpro
iketh
Post by iketh »
please fix the graph window from relocating to negative coordinates when you close it on a secondary 4k screen located on the right of the main display... you don't even have a tile/cascade option to move it back into positive cords... I'm having to edit your ini files every time to be able to reposition the graph where I can use it
to repeat the bug:
1080p screen is primary on the left, 4k screen is on the right
open flashpro/kpro manager and maximize it on the 4k screen
open the graph anywhere
close flashpro/kpro manager
reopen, graph is now off the screen in the upper left corner
no other window bugs, just the graph... this bug does not occur if the 4k screen is on the left of the primary 1080
Re: *BUG* for both fpro and kpro
What Windows are you using?
iketh
Post by iketh »
10
Ok, we'll look at it.
