Injector Dead Time
ALS2386
Injector Dead Time
Post by ALS2386 »
Hi,
I was setting my Hondata Mobile App v1.2 and it ask for injector dead time. What is the exact amount to put there?
Just in case, I have the K20Z3 turbo with DW800cc injectors, a Wallbro 255 fuel pump, and CT Engineering modified stock fuel pressure regulator(which add 10psi) for a total of 63psi
Re: Injector Dead Time
Use whatever dead times you have set in your calibration.
ALS2386
Post by ALS2386 »
As I compare now, my current calibration is a base DW800 but with gas tables modified. The injector dead time(IDT) are the same.
Can you tell me if this DW800 base calibration IDT numbers are suppose to be the same for my car with all the previous mentioned set up, or the IDT numbers should change?
If it has been tuned with those dead times you should leave it alone or you will have to retune.
