Base Fuel Pressure
AREA876
Base Fuel Pressure
Post by AREA876 »
Which method is best for setting base fuel pressure, cycling the key on and off or starting the vehicle and disconnecting the vacuum hose to the fuel pressure regulator
Re: Base Fuel Pressure
Disconnecting the vac line from the regulator at idle is how it should be done.
