Maximum Throttle Pedal opening @WOT only to 92%!
R-12914
Post by R-12914 »
Hi Hondata,
on my FN2 with Rotrex Supercharger the Throttle Pedal opening at WOT only to 91-92%.
The Throttle Plate opens to 102-103%.
I seem to remember that this is in the original condition was already so?
Why is this so and can you fix this issue?
Here is a Screenshot about this issue:
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Maximum Throttle Pedal opening @WOT only to 92%!
If the plate is getting to 100% then it does not sound like there is a problem. I would only be concerned if you were at a pedal of !00% and the actual throttle plate was only at 90%.
