Rotrex-Supercharger-Kit @10PSI makes more boost...
R-12914
Post by R-12914 »
Hi Hondata,
i have a Rotrex supercharged FN2 with boost @10PSI (0,69 Bar).
But on my Datalogs, the supercharger makes more boost than 10 PSI (0,69 Bar).
On my Logs i have peak boost of ~10.44 PSI (~0,72 Bar).
I only have installed the OEM Map Sensor are read maximum of 10 PSI (0,69 Bar) of boost.
Arise measured errors characterized in my case?
In this case, is it necessary, to install a Hondata 4 Bar Map Sensor to measure correctly and to avoid measurement errors?
Max boost of 0,71-0,72 like this:
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Rotrex-Supercharger-Kit @10PSI makes more boost...
You are right at the limit of the stock map sensor. You may want to get the Hondata 4bar so that you can read above that level as a restriction somewhere could cause it to go above that level.
