Turbo ep3 with water meth and high/low boost
conalmcn
Post by conalmcn »
Hi, I'm nearly finished building my turbo ep3 with a k20a2 (pra ecu) with a kpro4 ecu. I'm just getting round to wiring in The water meth and have a few issues. I am using the e29 pin currently for low and high boost. I want the same switch to also arm the water meth is this possible for it to do both?
The kit has a float switch is it worth connecting this to kpro as a fail safe or would it be better to just connect it to a buzzer or led?
Also it is a stage 1 Devils own kit with its own adjustable pressure switch. Can I ditch this switch and just set the boost levels on kpro that it kicks in at? On page 10 of the webpage below is a wiring diagram. If I can remove the pressure switch do I just run an output from kpro to pin 85 of the relay in place of the mechanical pressure switch? Or should I just stick with the way it is?
http://www.methanol-injection.co.uk/PDFs/stage%201.pdf
Thanks in advance
Re: Turbo ep3 with water meth and high/low boost
You can use the same input to do multiple things as long as you want them to come on at the same time.
I can't tell you what will work best in this case. You will have to try it how you want it and see what works best in your individual case.
conalmcn
Post by conalmcn »
Thats brilliant one thing down haha. Well looking on kmanager there is no way or arming it at a set boost level so if that's the case I'll just use the pressure sensor and let it do its job.
