Cold start E85 Fn2 problem, help ?
goppe
Post by goppe »
Hi there, I have a Fn2 with a stock K24, CT-E, Walbro 255 l/h and DW 1300 CC... Running E85.
I have issues with cold start. What do I need to change in Flashpro, I have read about Water temperature fuel compensation cranking but I don't know what numbers I should use for my setup so it is easy to crank up :)
53F=?
35F=?
0F=?
-18F=?
Help please...
Re: Cold start E85 Fn2 problem, help ?
You may want to read what others have found at: http://www.k20a.org/forum/showthread.php?t=85056
Below about 70F E85 needs much more fuel to start.
goppe
Post by goppe »
The link you sent only works on Kpro, Flashpro does not have that setting?
Do you think this numbers I wrote will work?
You will have to try it and see.
goppe
Post by goppe »
What tables shall i change ?
