Will increasing the load index columns benifit a NA engine?
jgonzalezrt
Post by jgonzalezrt »
If I increased the load index columns in the resolution table to say 13, 16, 20, or 24 columns instead of 10 for NA using the show boost tables would this give me more tuning options, less interpolation? I have played with the 13 column table and adjusted the load index to spead the the load evenly between the 13 columns, something like 26"mmhg-0.1.But I have not uploaded this to my ECU, just was playing around with the software. So my question again is will the give me more tuning options/benefits?
Jaime
Johnny_9
Re: Will increasing the load index columns benifit a NA engine?
Post by Johnny_9 »
May benefit in the low load/low rpm area, if u have overlap cams - different vacuum on deceleration vs stock cams, assuming yr (larger) injectors are linear at low pulse width
jgonzalezrt
Any one else have any thoughts on my question? Is there any benefit to having more than 10 load points for a NA engine? Hopefully hondata will chime in. Thanks in advance.
jgonzalezrt
Spunkster could you clarify this for me?
It really will not help that much and just make you have to spend more time on the dyno getting every new load index correctly tuned.
