Does FlashPro support Accord 2015 (US) ?
lorem
Post by lorem »
Hi,
I just ordered a Hondata FlashPro online. The site shows that my car was supported (2015 Accord Coupe V6 AT) and that's why I ordered it. But then I downloaded FlashPro Manager, selected all the vehicles to install, and found that the list contains only Accords up to "Accord US V6 AT 2014".
Can anybody tell me if the 2015 Accords are supported at all? If not I may need to cancel my order. Thank you.
Re: Does FlashPro support Accord 2015 (US) ?
2015 V6 AT is supported. To be sure get your ECU part number and check on the FlashPro page of the website.
What you are seeing in the new calibration window is that the same ECU may be used over multiple years, so the 14 and 15 use the same calibration.
lorem
Post by lorem »
I tried to find the ECU part number, but the ECU seems to be covered under the plastic cover. I haven't found obvious mounting points for the plastic cover, so have no idea how to remove it.
I attached the picture of the engine cover. Can you give some instructions how to remove it?
Thanks.
lorem
Post by lorem »
Well I found out... I just need to pull it straight out. But I haven't seen the ECU or any numbers under the cover. It's mostly just metal.
I do have seen some numbers in nearby places, but those don't look like a computer board. I'm pretty sure the engine model is J35Y1, but not sure which one is the ECU number. None of the numbers have the format starting "37820-" as specified by this page (https://www.hondata.com/index.php?_route_=flashpro). The only thing close is "F5G0-AA5". But entering this into the webpage doesn't confirm that it's supported.
I attached all the pictures of the parts containing numbers here.
The ECU is under a plastic cover. You should see 3 large plugs going into it.
