right cam angle
pk20na
right cam angle
Post by pk20na »
hi,
when my datalog runs, the tables shows 50 degrees and cam sensors shows 48
i need to add more fuel on 8 and 9 colum from 4000rpms to 6000rpms
my question, should i use the 40 or 50 degrees cam?
before cam 45 on sensors, the tables shows 40 degrees after 45 on sensor the tables shows 50 degrees on the table
thanks for your advice
Re: right cam angle
The closest table - 50 degree
fugazzyek
Re: right cam angle
Post by fugazzyek »
thanks for the answer
i was detailing more the datalog for all the cams
17 the closer is 20
28 would be 30
and 13 to 10
24 would be 20 am i right?
Re: right cam angle
Yes. When tuning it is best to set the cam angle tables to all one value eg 20 degrees to make fuel changes easier.
