Idle control on cl7 euro r cable throttle
chukhchukh
Post by chukhchukh »
Could i tune the idle control through my kpro? Because i found the idle was very unstable and holding on high rpm when idle after i modify the big bore throttle s90racing. Thank a lots
Re: Idle control on cl7 euro r cable throttle
Block off the idle port. If the rpm does not fall to < 500 rpm, your throttle body has air leaks, and the idle valve will not be able to reduce the idle speed.
How are you using a K-Pro on that vehicle?
chukhchukh
Hondata wrote:Block off the idle port. If the rpm does not fall to < 500 rpm, your throttle body has air leaks, and the idle valve will not be able to reduce the idle speed.
Thank you for your recommendation.i had tried to block off the idle air port and found the rpm will drop nearly turn down the engine. But i feel a strong suction from the idle air port seem to push the rpm so high.but when i waiting for few second, sometimes this idle valve will reduce slowly in order to slow down the rpm. whats wrong with this? When i driving , my feet leave the throttle pedal ,the rpm will still keep seem i never leave the pedal. Thank you
