WB offset Voltage
Javcolin
WB offset Voltage
Post by Javcolin »
Hi,
What is the highest offset voltage you can can run to be considered a good ground point?
Currently I'm using -0.1 and i was wondering if my ground is Ok. I read the other day that Hondata says if it goes above XX volts that means that the ground point was no good,but i can't find the post.
Re: WB offset Voltage
If you have an offset and it is the same offset for the entire rev range then it is fine.
