Reflash with 5.06 FD
gsrr
Post by gsrr »
Good Day
Does the cruise control will still work if i Reflash the ECU and replace the FD?
I know the speed will not be corrected, but will i retain cruize function?
I know cruise control that it will be desactivated if I replace the FD on oem programation.
Regards
Re: Reflash with 5.06 FD
You will have to check with someone that has done this modification to see if it works or not.
I do not believe it will work correctly as there is no gear ratio tables.
