Lantecy "dead times" TRE 1600cc injectors
bearkats10
Post by bearkats10 »
having a hard time starting and idiling my car when it gets warmed up I looked and looked for answer. I tried to adjust ect + percentage table and wont do nothing JUST WANTED TO KNO IF ANYINE HERE HAD THE LATENCY FOR 1600CC INJECTORS FROM TRE "DENSO STYLE " INJECTORS....
Re: Lantecy "dead times" TRE 1600cc injectors
You should be around 1.5-1.6 ms at 12V and 1ms at 16V. eg
0.00 8.09 10.11 12.13 14.16 16.08 24.55
2.33 2.33 1.80 1.52 1.34 1.20 1.20
bearkats10
would this be correct for e85?? thank u very much
bearkats10
also injector company said pulse should not be less than 3ms to account for the 1.3ms dead time
how do I do that....
It will be the same for all fuel. I don't understand the comment about using 3 ms. You'll need to go way below 3 ms otherwise there would not be any fuel control.
