wanted Alpha n base cal for PRA ecu K20A2
Posted: Mon Mar 28, 2016 3:01 pm
by white_twin_cam
The only Alpha N base cal I see is for PRB ecu and when I upload that I get wrong cal for ecu error. Anyone have Alpha N cal for PRA or know what I need to disable to stop error? Thanks.
Re: wanted Alpha n base cal for PRA ecu K20A2
Posted: Fri Apr 22, 2016 10:42 pm
by ce
Create a new PRA calibaration. Enable Alpha-n in it and adjust the table values for TPS % so it matches the PRB alpha-n calibration.
Then you can right click in the tables and select import from calibration and import them from the PRB calibration. You need to do this for each table. Takes some time but it should work.
Hope it made sense :)
