vss frequencies
oxxy
vss frequencies
Post by oxxy »
Hi hondata,
I have a 01 honda civic and im currently swapping it with a k20/k24 setup. I bought the prc kpro4. But im running into dead end because the speedo is not responding. So i got no vtec. I read the article about frequencies of 02-04 and 05-06 vss from the rsx. Then when im about to purchase the vss, again it is branched. One vss is for the type s and another is for the non type s. But both is for 02-04 rsx. Are this vss both the same ? Because non type s means it is not meant for 6 gear transmission. While im using the 6 gear. Please tell me which vss to buy. The type s vss is sc456,78410-s6m-n01
Non type s vss is sc425, 78410-s7a-g01
Thank you so much for the help
Re: vss frequencies
What transmission are you using?
oxxy
Re: vss frequencies
Post by oxxy »
Hi spunkster
I am using the 03 dc5 transmission 6 speed. So based on the articles i read here, that i must use a low frequency vss. Thats why i wonder which of the 2 items i should buy. Please advise. Thank you
Re: vss frequencies
AS long as you use an 02-04 RSX Type S engine harness there is nothing special you must do. You should you the VSS that comes with that transmission.
oxxy
Re: vss frequencies
Post by oxxy »
So is there any suspection of my engine harness that's not properly installed/working ? So if you say the vss that comes with the transmission is fine, that means basically i dont need to buy any vss, right ? And FYI during swap, i did not install any k swap conversion harnesses. All wiring is done by the tuner himself. While most people uses conversion harness. Is it a point where i should look up to ?
Thanks for the feedback spunkster.
Re: vss frequencies
You will need to discuss this with whoever it is that did the wiring.
nuk1ear
Re: vss frequencies
Post by nuk1ear »
are you saying the speedo in the cluster is not responding or the VSS readout in kmanager is not responding?
