Flashpro and plx devices norrowband output
iselfdevi
Post by iselfdevi »
Hi.
I have the plx device narrowband output wired up to the signal wire on the oem secondary o2 sensor (cut and soldered in). I keep getting mil p0137. Am I missing something. I'm tuned on flashpro.
2012 Acura TSX 4cyl 6MT - flashpro - ct-e supercharger - ct-e icebox intake - deatschwerks 550cc injectors - RV6 exhaust/pcd - Vit tuned
Re: Flashpro and plx devices norrowband output
You really can't use a simulated narrowband output from before the cat and allow that to be used after the cat as it will not show any difference which is what the ECU is looking for.
iselfdevi
Post by iselfdevi »
Ok thank you.
