Will the AIM GPS work in kpro4?
paintballwill
Post by paintballwill »
I know that kpro needs a wheel speed sensor so vtec can change over at a certain mph. I'm wondering if I can get around that by using AIM's GPS to get the speed that way? If I'm doing a brake stand burn out and not moving the wheel speed sensor will know the wheel is spinning but the GPS will not. I'm not sure what else the wheel speed sensors use is for the kpro, can anyone help?
I have a 92 Miata that I swapped a built k24/20 into. Using kpro4 and an AIM Strada. For pictures you can find me on instagram @goodolsanta
Re: Will the AIM GPS work in kpro4?
No, the K-series ECU cannot use a GPS input for speed.
paintballwill
Spunkster wrote:No, the K-series ECU cannot use a GPS input for speed.
Damn, thank you
