Dual Stage Water/methanol
Javcolin
Post by Javcolin »
Hi,
I´m toying with the idea of running a dual stage water methanol, the plan is to run 1st stage to activate the pump and this will feed the first Nozzle, the second stage will go to a relay that operates a solenoid that will feed the second nozzle,
This is my first attempt on Smanager, i have done nitrous on Kpro, does the first Aux arming (input) will arm also the second Aux system as Kpro does, or each aux input must be arm (wired) individually?
Second question i see B5 as an input this is the AC switch, i dont run ac anymore, can i just push that switch to arm my stage 1, or does a new switch has to be wired to that specific pin?
Thanks in advance
Re: Dual Stage Water/methanol
They can arm from the same trigger.
You cannot just use the existing AC switch. It would need to be rewired, or a separate switch wired directly to the input.
Javcolin
Post by Javcolin »
Hi,
So I can chose from Aux 1 Input AC switch to arm that Stage, and select same AC Switch as an input on Aux Input 2 as an Input and both stages will be arm just picking up a different output correct?
correct
