Fn2 cruise control not working?
goppe
Post by goppe »
Hi, my cruise control doesn't work anymore... I have tried set Fn2 euro gear ratios but didn't work either.
I have a 4.76 final drive from EP3.
Do I need to set gear ratios from civic si and change the 6's gear ratio?
R-12914
Re: Fn2 cruise control not working?
Post by R-12914 »
What is happening, if you use the FN2 gear-ratios and your 4.76 as final drive like this?:
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
goppe
Post by goppe »
Did not work with civic si and changed 6s gear and it did not work with the sugestion you came with :/ anyone know how to fix this?
R-12914
Post by R-12914 »
Do you have push (activate) your cruise contol on your steering wheel like this?:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
goppe
Post by goppe »
Yes that works but the cruise control will not kick in when I press the set button.
It worked in october last year, the car has been in the garage over the winter and I took it out in the beginning of april, the cruise didn't work now.
How is the wiring system for the whole cruise setup, maybe I have disconnected some wires by mistake?
I have tried return ecu to stock and upload it again, I have a feeling that the fault is from the calibration... Maybe I should try and disconnect cruise in my calibration and upload and then take it for a drive and later upload again when cruise is connected in the calibration?
R-12914
Post by R-12914 »
goppe wrote:Maybe I should try and disconnect cruise in my calibration and upload and then take it for a drive and later upload again when cruise is connected in the calibration?
Yes, try it!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
goppe
Post by goppe »
Still not working...
goppe
Post by goppe »
Anyone know what to check for ?
R-12914
Post by R-12914 »
Can you please add your Calibration?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
goppe
Post by goppe »
It has worked before with civic si gear ratios, I have 4.76 final drive.
R-12914
Post by R-12914 »
Do you have try a MAF or MAF calibration with MAP fuel tables?
If not, please try it!
Please have a look, if the problem with it is yet!
You use a MAP calibration!
MAP calibrations are for race use only and this one not have some features!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
goppe
Post by goppe »
It has worked before with MAP calibration and my friend has MAP calibration and all features works. Both cruise and trip meter.
My trip meter works with this calibration but not the cruise. Cruise has stopped working when I uploaded a "new" calibration to my car in April.
typer86
Post by typer86 »
1. install the latest beta version of hondata
2. restore your ecu back to stock - switch off ignition and wait 1 minute
3. Then: upload the RSP calibration only (which I provide you in the other thread) - MAP (race cal) not supported for FN2
4. Record the drive for 20 - 30 minutes (start logging if the engine is fully warmed up!)
5. upload the log here
R-12914
Post by R-12914 »
In addition you can try to disconnect the battery, wait a few minutes and reconnect it!
Then reupload your map!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
