Nitrous Aux output arm signal
Lyle_57IAL
Post by Lyle_57IAL »
Hello Hondata !
In the process of using an Aud output to fire my nitrous solenoid and wind in fuel / timing corrections etc.
The digital arm signal for this output - that that by applying a ground or a voltage to the Ecu input ?
Cheers :)
Re: Nitrous Aux output arm signal
It depends on which input you are using. Some are grounds and some are 12v.
