Unable to lock hondata to ecu
Dilly
Post by Dilly »
Hi I bought a new hondata for my 2007 fd2r Honda.
I cant lock the new hondata as it gives me errors stating that it has been tuned before.
I bought the car used from a dealer and if it is tuned I cant possible get hold of the old hondata.
Anyways to solve this?
Ecu number :37820 rrc j01 4828 101341
Country: singapore
Re: Unable to lock hondata to ecu
It has not been programmed by a FlashPro; rather the ECU has been opened up and programmed by some other device. Unfortunately that programming has bugs so that if you try to program via OBDII it bricks the ECU. Hence the warning.
Your options are to replace the ECU or get the ECU programmed back to stock.
Dilly
Post by Dilly »
I will get a hold of a civic si ecu and ask my tuner to program it.
