No VSS readings
ctsupplee
No VSS readings
Post by ctsupplee »
I have a 2005 RSX base model manual transmission with a K24A2 engine swap. I have the Kpro4 ECU, however, my speedometer does not work. I've checked everything else and I have sorta narrowed it down to the ECU/ECU wiring. This has been a problem for 2 months now. Any help?
Re: No VSS readings
Does the ECU datalog speed? I'd say to most likely fault is the speed sensor itself.
ctsupplee
Re: No VSS readings
Post by ctsupplee »
It hasn't been reading any sensor inputs, so no it doesn't read the speed but it also doesn't read any other values like RPMs for example.
Re: No VSS readings
Are you datalogging?
ctsupplee
Re: No VSS readings
Post by ctsupplee »
Do I need to plug in the one wire connector with 10 wires inside the ECU and plug the red VSS wire to the white/green VSS wire as shown here: https://www.hondata.com/tech-alternativ ... ngine-swap
ctsupplee
Re: No VSS readings
Post by ctsupplee »
I have not tried datalogging
Re: No VSS readings
You have to datalog in order to see readings.
