all 4 coils fire at the same time
Wolli
Post by Wolli »
i have installed and wired everything exactly like it should be. i get the power light, the ignition led pulses while cranking and after about 1 or 2 seconds, the sync light starts flashing slower than the ign light.
but the engine does not start. so i checked the timing of cyl.1, and it is okay. but after a while i recognized, that all 4 coils fire exactly at the same time!!
what can cause this?? did i get a cpr of a big bang engine (sarcasm!).
engine: b16a2, stock dizzy, transistor at q37 installed
i live in austria, so i have no possibility to try a different cpr unit or a different s300!!
when i read other threads i often think, this stuff grows on woods in the states ;)
p.s.: is this spunkster in the installation video on youtube?
Re: all 4 coils fire at the same time
Can you post a video of the lights when cranking?
Wolli
Post by Wolli »
i can't upload mp4 files, so i have put the videos on my youtube channel: https://youtu.be/Rrh-FX-c4mY
Wolli
Post by Wolli »
here the check lights: https://youtu.be/Lp6rjZ-viYw
Who did the wiring harness for this vehicle?
Wolli
Post by Wolli »
it is the stock wiring harness. installation of the cpr was made by me.
car was running properly before!
What vehicle is this in?
Can you post pictures of the installation and engine bay please.
Wolli
Post by Wolli »
it is a 1992 civic EG6, with the b16a2 engine.
can't it be just a faulty cpr unit with a short circuit inside?
I can't see any ground on your thermostat housing. I also see what appears to be a butt connector and a scotch lock of some kind attached to possibly the power side of the distributor wiring. I really can't see any other wiring form the pictures.
Wolli
Post by Wolli »
ground on the thermostat housing is clean and good, and cannot play a role, because i have a good spark. and this cable to the power of the ignition is just for the relais of the alcohol injection!
Wolli
Post by Wolli »
hard to make a pic!
Has the distributor been modified?
Wolli
Post by Wolli »
the coil removed and a cap mounted. stock td-86u distributor.
i do not know, how you use the signal of the hall effect sensor with the cpr.
what will happen, if the transistor , which i soldered to q37, is faulty?
what will happen, if the distributor has a defect?
the dizzy or a ground and power cable can just be the reason for no spark, in my opinion.
but this looks like it is using the one lobe signal from the tach, instead of the four lobe signal!?
I would recommend that you return the distributor to stock and try running the car form that distributor without the CPR. Then if it works, hook up the CPR but to not remove anything from the distributor. There really is no reason to remove anything form it anyway.
Wolli
Post by Wolli »
can you please explain, what you think is the reason for this.
