Flashpro not detecting ECU
iShinto
Post by iShinto »
Hello,
This morning I uploaded a new calibration that I got from Vittune and it seems that an error occured partway through the process. The program light came on solid for about 10-15 seconds and shut off which was odd compared to how long it took to put in a new calibration before and now my car will not start and when I connect my laptop to Flashpro it now doesn't detect my ECU and it seems that Driver and Flashpro lights are on.
If anyone can help or have any insights on this matter would be greatly appreciated.
Thanks.
Re: Flashpro not detecting ECU
What is shown in the bottom left hand corner of FlashPro Manager?
iShinto
Post by iShinto »
Driver:Green, Flashpro:Green, OBDII: Red, ECU: Red.
I've tried looking at the connections on the Flashpro to see if it's bent in any way and they all look good, I've also tried re-plugging it several times and still not reading.
iShinto
Post by iShinto »
Initially I tried to reflash it without a laptop like I usually do and the program light this time would only stay on for 10-15 seconds and when I plugged it into my laptop when I got back in I got the error message that said something along the lines of "Check WEN upload has failed" or something like that.
It sounds like the battery may be dead. First check all fuses to make sure there are no blown fuses, then hook up a battery charger and see if it will show OBD2 with a green check.
iShinto
Post by iShinto »
Thanks for the help Spunkster, for some odd reason after I sent that message I was able to go out and get the Calibration to work without interruptions. So odd xD
Malikzzz
Post by Malikzzz »
Spunkster wrote: Tue May 17, 2016 9:44 am It sounds like the battery may be dead. First check all fuses to make sure there are no blown fuses, then hook up a battery charger and see if it will show OBD2 with a green check.
flushpro Green obd2 Green ecu red now what
Check fuses and power cycle everything.
Jackfro5t
Post by Jackfro5t »
Spunkster wrote: Mon Jul 27, 2020 1:08 pm Check fuses and power cycle everything.
By power cycle does that mean turn everything off and back on again?
It means turn everything off, unplug it and or reboot it.
Jackfro5t
Post by Jackfro5t »
still no ecu detected?????
Jackfro5t
Post by Jackfro5t »
how do i unlock my ecu this isnt worth 800 dollars
What vehicle are you referring to?
