S300 Boost Control Help
AAAHONDA
Post by AAAHONDA »
Ive hooked my boost control solenoid up to Pin A11 and it worked for a couple of hours and now nothing. Ive since read that i need PWM BOOST CONTROL ECU KIT(does any one have fitting instructions). Is it too late to fit?
Cheers
Re: S300 Boost Control Help
You will have to first check to see if your ECU has boost control components installed: http://www.hondata.com/help/smanager/bo ... st+control
IF they are and it is not working then you may have something wired incorrectly and it has burned the main transistor out. You could try replacing it and see if it resolves the issue. You should also check your solenoid by touching it to the pos and neg terminals on your battery to see if it clicks.
