Honda Elise
Stane
Honda Elise
Post by Stane »
Hello ,
I have swapped K20a from Integra Type R (JDM DC5) to Lotus Elise S2( Toyota , 2006) , got Kpro4 and Innovation conversion loom from Monkey wrench racing . I have to wire :
- RPM output
-MIL output
- VSS output
- Oil pressure output
to Lotus instruments ( dash).
Wiring diagram for the Instruments is not detailed , I don't know where to connect wires to make it work .
Thank you very much for any advice .
Stane
Re: Honda Elise
Do you have a Federal Elise or something else?
For the Fed Elise rpm, speed, MIL, oil pressure etc are all handled by the CAN bus. With the KPro CANH & CANL to the Lotus harness, select Lotus for the KPro4 digital output, and it should work.
For fuel level & AC you have to do more wiring. See http://www.hondata.com/help/kmanager/lotus_dash.htm
Stane
Re: Honda Elise
Post by Stane »
My Elise is from UK, I bought it in Germany .
Thank you ,
Stane
Re: Honda Elise
The KPro CAN output only has been tested on US Elise/Exige clusters. We do not know if it will work on any other cluster.
Stane
Re: Honda Elise
Post by Stane »
Shall I try with cluster converter ? What do you think about installing Dash2 Pro : http://www.demon-tweeks.co.uk/motorspor ... -dashboard
MartynL
Re: Honda Elise
Post by MartynL »
Hey Stane... I have the Hondata Lotus Cluster coverter sitting in my garage, not being used, if you need one?
I had intended on running a 2008+ dash with mine, via the multiplex output, but as mine was an early Rover-engined car, there were too many differences to overcome.
Yours if you want to make me an offer!
Stane
Re: Honda Elise
Post by Stane »
Hi Martyn,
I got cluster converter , thank you very much for your kind offer.
Stane
