CAN output v4
Korn4900
CAN output v4
Post by Korn4900 »
Is it possible to use the CAN outputs on the digital input for a factory honda CAN bus?
Re: CAN output v4
What are you trying to do?
Korn4900
Re: CAN output v4
Post by Korn4900 »
The RDX rear diff usses the can bus to communicate with 4 other sensors and the PCM and abs unit
Re: CAN output v4
The KPro CAN output is for datalogging and has a couple of different formats. I'f you're trying to control the RDX differential, then this is outside the scope of what the KPro output can do.
Korn4900
Re: CAN output v4
Post by Korn4900 »
Would it be able to output the correct format to use let's say a TSX cluster?
Re: CAN output v4
No, it is not designed for this.
SilverRD1
Re: CAN output v4
Post by SilverRD1 »
why not? there is a demand for it now. make it happen please.
