2004 TSX K24 into my 2004 CRV
wilcoxl
Post by wilcoxl »
Car is a 2004 CRV 5 speed. Engine is a 2004 TSX. I will retain the stock 5-speed from the CRV.
I assume I can just use the TSX long block and bolt on my CRV accessories (power steering, alt, a/c) and use the CRV engine harness. Anything different about the intake manifolds that might be a concern?
For ECU, I am wondering if I can get Kpro installed in my factory 2004 CRV manual edu OR can I just use the TSX ecu (are the plugs exactly the same?)
Thanks for any info.
Re: 2004 TSX K24 into my 2004 CRV
What is the part number on the CRV ECU?
wilcoxl
Post by wilcoxl »
37820-PNL-E02
I'm sorry, but we do not have anything that will work with that ECU.
wilcoxl
Post by wilcoxl »
I'm wondering if I can just use the 2004 TSX manual ECU in my CRV. I know that the TSX ecu will look for throttle by wire so I will have to get the accelerator position sensor from the TSX.
Will the cabin harness from the CRV plug right into the TSX ecu, so that my gauge cluster works appropriately?
I do not believe any of these will work in combination with one another.
wilcoxl
Post by wilcoxl »
So can I buy an ECU that is K Pro compatible and get a tune for a stock TSX motor?
The TSX ECU cannot be used, and you cannot use the stock ECU with drive by wire.
Post a picture of the inside of the stock ECU.
sass
Post by sass »
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
