Bugs in Flashpro-Manager!
R-12914
Post by R-12914 »
Hi Hondata,
since a few software versions I observe already the following errors in FlashPro-Manager:
1.
Under "Check for Software Updates" the date from the "Most recent production version" is not correct!
Written is: "20 Apr 2015", but correct is "20 Apr 2016".
I see that right?:
2.
Under "Settings" we have the option to activate "Automatic Updates" -> "Automatically check for new software versions" and "Misc" -> "Display message with result of ECU upload" like this:
Under "Last checked update" the date is correct, but if a new softwareversion ist available, no message window pops up!
The same as well as after i upload a Map to the ECU (via Flashpro in the car) and reconnect to the notebook, the display message with result to ECU upload (successful, and its always successful) only sporadic pops up and not always!
3.
Under "Fuel" -> "Fuel Economy" you have still not updated the changes in the help file like this:
Your changes:
To me it is clear now, but many people still do not know, what this option means and when this option has an effect (many people constantly asking the same!)
A description of these options in the help file is very long overdue!
And please note you add furthermore, that this options only have an effect on MAF-based (AFM- and Hybrid-calibrations), MAP-based (race) calibrations are no longer supported, as you have often written in the forum!
Thank you for fixing this bugs/things! :)
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Bugs in Flashpro-Manager!
1. Yes, it should have been 2016.
2. I don't fully understand. You seem to be reporting two problems. Check for update will not show anything if the software is up to date, and the last check date should be updated.
3. The help file has been updated.
R-12914
Post by R-12914 »
Hondata wrote:1. Yes, it should have been 2016.
1. Ok, thank you!
2.1: Ok, if the Software is not up do date, a window must pop up, is it right? Does the automatically AutoUpdate works (without manually checking?)
2.2: After i upload a Map to the ECU (via Flashpro in the car) and reconnect to the notebook, the display message with result to ECU upload (successful, and its always successful) only sporadic pops up and not always!
3. Help file is updated in the next Flashpro-Version?
Thank you!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
