S300v3 issue
daddygame
S300v3 issue
Post by daddygame »
I just sent my ecu for upgrade at Hondata but now when I've got it back the car won't start it's acting weird no sensors are being read by the ecu nothing.
I also had the boost by gear components installed.
My question is:
Is it possible to have the boost by gears components installed but not be running boost by gear set up?
Could u still use it for waste gate pressure set up? I did that for future upgrades. I was planing to run boost by gear in the future so I decided to have it done. But like I said the car doesn't want to start or anything.
Re: S300v3 issue
You should still be able to use it without boost by gear. Did you upload your calibration to the ECU?
daddygame
Re: S300v3 issue
Post by daddygame »
yes i did. i put back the copy of the same calibration that was taken from the ecu before it was sent for upgrade
Re: S300v3 issue
That calibration may be corrupt. Have you tried uploading a new calibration from the New calibration button?
daddygame
Re: S300v3 issue
Post by daddygame »
yes and i have different calibration that i have had from the past. nothing works the check engine light is on. No sensors or anything read on the laptop no error codes nothing
Re: S300v3 issue
From Help, About, what is he version of software you are using?
daddygame
Re: S300v3 issue
Post by daddygame »
2530 is the firmware version and the serial ill have to check it out when i get home from work
