Idle Ignition Control Range
Posted: Mon Jul 04, 2016 4:40 am
I'm running KManager 4.2.6.0
I think there maybe a bug which is causing the "Idle Ignition Control - Range: Max Advance" setting to not get saved as part of the .kal file.
If I set anything other than the default of 5, then save the file, restart KManager and re-open the saved file, then it changes back to 5.
I've tried this with a brand new calibration so it doesn't appear to be specific to my ECU or calibration.
I've compared the text content of a .kal file with this value set to 5 with the text contact of a .kal file with the value set to anything else and there are no differences, which leads me to believe KManager may not be saving this value as part of the .kal
If I set this value and upload it to the ECU then it appears to work as it has the desired effect. However if I download the calibration from the ECU then KManager shows the default value of 5, not my uploaded value.
I hope this explanation makes sense.
Matt
Matt
