grounding PRB ECU case, is it needed?
Aerodynamic
Post by Aerodynamic »
I have Hondata PRB ECU in an Opel Speedster and the ECU is sitting on a plastic sheet
not connected to ny metal like it is in a Honda Civic for example.
Should I connect a wire between ECU case and car grounding Point?
Br, Per
Re: grounding PRB ECU case, is it needed?
No, the case does not need to be grounded.
