Car stalling if I give it gas
1989 crx si
Post by 1989 crx si »
So today I was messing around with my car, I wanted to turn on my launch control. After I did my car started to idle awkwardly, then it was fine. But when I barely gave it some gas it would stall. If I stepped on it it would hesitate from 1000-2000 rpm but after it would hit the Rev limiter just fine. I turned launch control off but it would still die if u gave it any gas. Is there anything I did wrong?, how do I fix this?, have you guys had the same problem? I need help ASAP!!!
Thanks for your time
Re: Car stalling if I give it gas
Try closing the program, reopen, load your calibration and re-upload to the ECU.
1989 crx si
Ok I'll try it
1989 crx si
Nope, I think it is running lean, my setup is a b18c5 with toda stage two cams, full exhaust, intake, intake manifold, throttle body. Does anybody have a calibration similar to this or what else can I do?
1989 crx si
Something else I forgot to mention, I have just recently bought the car and I don't have the original calibration they tuned it with
