need help with possible Coil on plug retrofit
dunesman59
Post by dunesman59 »
Can someone one tell me if the hondata coil on plug conversion works with the ECM in my car its a P28-obd2a ecm with S300. im having alot of issues with this car as someone else did a b18c swap and hacked it all together so it hardly runs and i have noticed intermittent no spark issues and i also noticed hondata only reading 30% throttle while at 100% throttle.
Re: need help with possible Coil on plug retrofit
The CPR will work with that ECU, but you really need to fix the problems you have first as it is not meant to fix already existing problems.
