New S300 problems
blacksi76
New S300 problems
Post by blacksi76 »
Car starts and drives good, idles perfect, cant get the ecu to datalog and when ot does.... Erratic codes
Re: New S300 problems
What is the serial number on the s300 board inside the ECU?
Who socketed the ECU you are using?
blacksi76
Post by blacksi76 »
Serial number on the new version 3 inside on the board is 37774
From the help and about section I'm running 2.3.0 released may15'2014
I just sent in my ecu to hondata a few months ago for the s300 version 1 upgrade , so it was all done at hondata
You need to download the most recent version of software from the software section of the website. The version you have is fairly old.
blacksi76
Post by blacksi76 »
Ok i will do that now, would this cause the problems with all thw codes? And the intermittent datalogging?
This is the first thing you must do to rule it out as a possibility.
blacksi76
Post by blacksi76 »
going to check now...give me a few minutes
blacksi76
Post by blacksi76 »
Ok, I installed the new software, uploaded it...and NO CODES!!! And Datalog function works perfectly...Thank you Spunkster...
Next question, I have my wideband hooked up to Analog 0 using the analog input plug directly into the S300, how do I select the wideband to read from Analog 0 ? In close Loop advanced theres no dropdown to select analog 0 as the input.
I also cant datalog from my laptop using Bluetooth without using the datalog cable, and my laptop is paired.
I also cant get my Hondata Mobile App to pai either..
Thanks...
To run closed loop form the wideband you must input the wideband signal into one of the ECU analog inputs listed. You cannot do this form one of the s300 analog inputs.
blacksi76
Post by blacksi76 »
sorry I run in open loop, closed loop is disabled, so how can I use my wideband for analog 0 in open loop?
blacksi76
Post by blacksi76 »
I figured it out...On the display, I added a sensor, Analog 0, NGK AFX...
