Aim MXL set up
radave
Aim MXL set up
Post by radave »
Hi ,having probelms communicating with aim MXL via Aim convertor .The ecu is running 4.2.6 software which doesnt match the instructions supplied with the Aim convertor
Thanks Dave
Re: Aim MXL set up
What is the serial number of the K-Pro board inside the ECU?
radave
Re: Aim MXL set up
Post by radave »
Hi ,thanks for the reply .The serial number is 15089
Dave
Re: Aim MXL set up
Only the K-Pro 4 can send the signal needed for the AIM dash. I am not aware of any converter from AIM to make this work with older K-Pros.
Re: Aim MXL set up
The older KPros can drive the MXL using the ECU multiplexer output and the AIM adapter X05EFIHKPRO.
In KManager set the multiplexer output to 'datalogger 9600 bps', then wire the AIM adapter to the SEMFJ pin.
There is some outdated information in the AIM instructions which tell you to edit the KManager.ini file, which you don't need to do.
radave
Re: Aim MXL set up
Post by radave »
thanks for the info ,but the only option in the multiplexer box is disable or enable no option "datalogger 9600 bps"
Dave
Re: Aim MXL set up
What software version are you using?
