CPR box contents
L_S_i
CPR box contents
Post by L_S_i »
Hi guys, on the instalation sheets provided with the cpr kit it does not mention the Q37 transistor install, but it is mentioned on the online help file so i assume this is needed, but the kit supplied doesnt come with a supplied transistor, my questions is, was it supposed to be supplied with one? If so can you please provide a ref code so i can order one to install this asap. Thanks.
Re: CPR box contents
This component is included with all CPR kits. The component must be in the ECU for it to work. IF your ECU already has a component in the Q37 position then you do not need to install it.
If you need to order the transistor, it can be ordered here: https://www.hondata.com/accessories/q37
L_S_i
Post by L_S_i »
