Shifting from 1st to 2nd gear with Reflash basemap
teddytao18
Post by teddytao18 »
I am currently using the Reflash basemap in Flashpro manager, without changing any parameters. I noticed that when I shifted from 1st to 2nd gear at 7000+ rpm, there was a pause of power if the rpm did not drop to 4500. It seems that the rpm first dropped quickly to 4500, and then the car pulled forward, even with full throttle on the whole time. My thought is that with VSA on, there is some sort of protection. However, this never happened to the stock ECU with VSA on. If I released the clutch from 1st to 2nd shift very quick with the stock ECU, there would be a slight wheel spin instead of the pause of power. Does someone know how to remove the "pause of power" feature?
Re: Shifting from 1st to 2nd gear with Reflash basemap
What has been changed on the car?
teddytao18
Spunkster wrote:What has been changed on the car?
It is stock.
