b2 pin egr
FlashPro questions & answers specific to the FD2 Japanese Civic Type R
Malikzzz
b2 pin egr
Post by Malikzzz »
I have a question I also have fd2r Japan model I m going to boost my setup again previouly I had this problem b2 pin egr hondata recommend was not working is this the same reason it's not working according to some post fd2 doesn't have egr if yes kindly help me.what need to be done to control boost selonide.its a k20a .not k20z2 or any other.
Re: b2 pin egr
The CIvic Type R ECUs do not have that output. THis only works on US vehicles.
Malikzzz
Re: b2 pin egr
Post by Malikzzz »
so on which pin I should put boost selonide
Re: b2 pin egr
You can't. Boost control is only available on a US ECU as it states when you open a FN2 calibration and look at the boost control options.
Malikzzz
Re: b2 pin egr
Post by Malikzzz »
what are you suggest what should I do .I'm using flashpro
Malikzzz
Re: b2 pin egr
Post by Malikzzz »
Spunkster wrote:You can't. Boost control is only available on a US ECU as it states when you open a FN2 calibration and look at the boost control options.
any thing which solves my issue
Malikzzz
Re: b2 pin egr
Post by Malikzzz »
is any pin on ecu I can connect to control boost selonide ELD etc etc
Re: b2 pin egr
Malikzzz
Re: b2 pin egr
Post by Malikzzz »
So that mean flash pro can't Handel boost for Fd2 is any thing I do or I should I buy a US version ecu or what give me the soloution
Malikzzz
Re: b2 pin egr
Post by Malikzzz »
kindly keep us in ur mind too ABA-FD2 K20A IS also a clint so solve our problem
