Newbie looking to learn to tune.
xiong0374
Post by xiong0374 »
Where to start, I have a data logged for my drive and would like to start to learn how to tune. Not tune aggressively but enough to learn what to do. Any help would be apprieciated.
pepperdanky
Re: Newbie looking to learn to tune.
Post by pepperdanky »
FlashPro help file has all the info you need.
cybertza
Post by cybertza »
Yea, A good place to start is the help file, anything you cant find in there, is not for the novice, its very complrehensive, i have found that video's do help, but finding really good one's is scarce.
I highly recommend customizing your views before you start with everything, i dont know where all the custom ones disapeared to that VIT created, but if you can create similar ones it will be of so much help, especially when tracking down knocks, or funnies, and just the educational value of it is insane.
xiong0374
Post by xiong0374 »
Ok so I'm looking on the forum but I don't see the flash pro help files.
Is that in the flashpro website itself or on the program itself.
xiong0374
Post by xiong0374 »
Small issue MAP (" psi/) change to MAP (kPa) the value on my datalogger does not change. Example: it say 25.4/psi but when change to kPa value still at 25
How do I change value of psi to kpa
http://www.hondata.com/help/flashpro/index.html
Go to Options, Settings, Units tab. Also in the sensor list, right click on MAP then properties and make sure you change your units there as well.
