Pit Lane Speed Limiter
Weel
Post by Weel »
Hi,
Is there anyway I can configure KPRO to have a pit lane speed limiter, Can I switch an input to my ECU that I can use to cut my speed in 2nd gear to 40KM/H. Would come into the pit lane reduce speed and flick switch to ensure I don't go over that speed. Can anyone help?
Its for a endurance race car from New Zealand EK9 K20A
Re: Pit Lane Speed Limiter
You could try so use a nitrous/aux output to trigger at a certain speed and cut all fuel if conditions are met when turned on.
Weel
Post by Weel »
Thanks, how would you set this up?
You will have to look at the nitrous/aux parameters and see if you can get it to do what you want. It is not something that it is necessarily designed to do.
Weel
Post by Weel »
Maybe I could setup a switch for pit lane speed and then just have the output drive a light via a relay to show that I am sitting at 39km/h ?
Or could I just use a switch and drive the burnout limiter for a cetain RPM?
