Live tuning help
ITR1102
Live tuning help
Post by ITR1102 »
I'm having an issue with live tuning. I'm on the most recent beta version of KManager.
Live tuning tables are selected and the green check mark icon is shown; however, none of the live tuning changes have an effect. I have to hit the Upload button before the changes I made (to the fuel tables at idle for example) take effect.
Are there any known live tuning bugs in this version such as in the past, or is there something else I should be looking into? What could prevent KManager from sending the data into RAM?
Thanks,
Kevin
Re: Live tuning help
What tables are you live tuning?
ITR 1102
Post by ITR 1102 »
I tried making changes to the 0 and 10 degree low cam fuel tables and the low cam angle table. I tried doing them individually so that Live Tuning memory wasn't maxed out but it didn't seem to make a difference.
05typeR
Post by 05typeR »
I also tried live tuning with the low speed fuel tables (10,20 and 30*) and they are making changes but nothing changes until I upload.
Also the autotune not working as quickly as I thought either. . .not sure if its settings which are pretty simple to understand.
Tested ok here. Can you provide the calibration and a datalog when you are making changes?
ITR 1102
Post by ITR 1102 »
I'll do some more testing over the weekend and report back with the requested information.
When testing it last night to obtain a datalog for you, it operated correctly. The only change I made was to the selection of the live tuning tables. For my test last night, I selected only the 0 and 10 degree low cam fuel table, removing the low cam angle table from the selection.
