Floating Battery Voltage / Losing Crank Sensor?
MarkyMark203
Post by MarkyMark203 »
At the dyno the car was floating battery voltage under WOT. I replaced the alternator and secured all grounds in the bay. Still doing it. The next day at the track the car would fall on is face in fourth gear almost like it lost crank sensor (RPM going backwards. Here's the log for anyone who cares to help. Also here's a picture of where the problem happens in the log
Re: Floating Battery Voltage / Losing Crank Sensor?
Post the calibration as well.
MarkyMark203
Sure. Hang on...
MarkyMark203
Why is the KAL necessary? I was hoping you could see in the log? I'm sure it's not a tuning issue.
Without the calibration you cannot see what tuning is behind the issues and data .
MarkyMark203
The car is on the same tune from before the issue started.
