Do I need Ver.4 for E85 ?
Boosted920
Post by Boosted920 »
I have the Kpro version right before the built in blu tooth. So I believe it's Kpro3 ? Do I need to upgrade to Kpro4 in order to run the E85 GM flex fuel sensor ?
Re: Do I need Ver.4 for E85 ?
What is the serial number of your K-Pro board inside the ECU?
Version 4 K-Pro is needed.
Jprusso08
Post by Jprusso08 »
Spunkster wrote: Mon Oct 10, 2016 9:21 am What is the serial number of your K-Pro board inside the ECU?
i know i am responding to a very old post. i too have a version 3 kpro with a serial number of 13008 on a PRB-a07 ecu. so there is no way to use the digital connectors on the v3 board to connect the gm flex fuel sensor? thank you
No, you must use the v4 K-Pro.
