trouble with plx sm afr
tweenpix
Post by tweenpix »
hello i have trouble with PLX SM AFR, when i add extra fuel, my gauge is show "LEAN", but must show "REACH".
voltage is 5v on d14 when is show lean
https://www.youtube.com/watch?v=NyBx1NYZIy4
bad sensor or bad controller plx?
datalog and calibration with video
https://youtu.be/5lCRFkfdJE8
Re: trouble with plx sm afr
Do not use D14 as it cannot read the full voltage range. Use D10 or one of the other inputs instead.
tweenpix
Post by tweenpix »
Spunkster wrote:Do not use D14 as it cannot read the full voltage range. Use D10 or one of the other inputs instead.
my p28 is modified for read 0-5v on D14
i can set fuel in calibration and my engine work in IDLE on 19-20 afr
if i set more fuel and my afr less then 10.5~11 PLX is showing LEAN, if i decrease fuel ~% and my AFR more then ~10.5-11 PLX is show actual AFR
Without the calibration and a datalog it is impossible to speculate.
tweenpix
Post by tweenpix »
Spunkster wrote:Without the calibration and a datalog it is impossible to speculate.
update first post
If you are referring t the 1 minute mark then it appears to be reading correctly as the voltage in put is around 5 volts and it is showing it is very lean.
If it is reading incorrectly on the PLX itself, you might want to contact them for assistance to determine why it is reading inversely.
tweenpix
Post by tweenpix »
Spunkster wrote:If you are referring t the 1 minute mark then it appears to be reading correctly as the voltage in put is around 5 volts and it is showing it is very lean.
thanks
tweenpix
Post by tweenpix »
i'm resolve problem.
replace WB sensor
