P006 on s2000 new install
Pcc5001
Post by Pcc5001 »
I recently installed the k pro conversion in my ap1 s2000. I am getting an intermittent p006 code that says the primary oxygen sensor is slow to respond. It's averaging about 6 starts after I reset the code that it comes back. Could this be anything aside from the primary oxygen sensor? It seems strange that the oem computer never said there was anything wrong with it but now with the k pro it is not working properly.
Re: P006 on s2000 new install
Are you sure that is the error code? There should be one more digit.
Pcc5001
Post by Pcc5001 »
I was just going off of memory on the actual trouble code. Apparently I forgot the code it's throwing. As soon as it pops up again I'll post back. I know it was saying the primary oxygen sensor was slow to respond.
Pcc5001
Post by Pcc5001 »
P0133 is the code. Bank 1 sensor 1 slow to respond
Please post the calibration you are using.
Pcc5001
Post by Pcc5001 »
The Calibration is "PRA- Euro Civic Type R/ s2000"
please post the actual calibration you have uploaded to the ECU.
Pcc5001
Post by Pcc5001 »
here it is
It sounds like you have a failing o2 sensor. I would recommend that you try replacing it.
